Uber Rate Card
UberAdrian
Where is it? I can't find anywhere in the app that shows time & mileage rates for the current market or even for completed trips.
UberAdrian
Login at https://partners.uber.com. Click on three lines at top left. Select 'fares' from drop down menu. Bob's your uncle.
I don't have that option.
318954
UberAdrian
Must be a jurisdictional thing. In the past there was "?" right on top of the mileage and distance in the trip logs that you could click on and it would show you the rate, but they removed that and I haven't seen a rate card since.
I have contacted Uber support about this 3 times and they keep bullshitting me without supplying an answer. They just pretend they don't know what a rate card is or what I'm talking about, even after I explain it to them very slowly.
Anyone from Canada with a layout like mine know how to do this?
reg barclay
Sounds like it might be because the OP is in Canada. Maybe it's set up diffrerently there.
