Totally dead in Mississauga
Token44
All comes down to location, and a bit of luck. I was online for three minutes when I got this one:
Token44
Something wrong, nearly 36 dollars for 14 kms and no surge?That can't be UberX.
Select
It says he drives select
Correct, and Select calls are even rarer than X in Mississauga.
Just meaning it comes down to location.
If you're online on X for 3 hours and haven't gotten a ping, you're either in totally the wrong place, or something else is wrong.
Wonder of the OP verified in the passenger app that he's actually showing as Online.
LAS0023
Did ok there last night. One guy said it was harder to get a ride the last week. He said the App took a while to find a driver and then he's usually far away.
Tdot
Hello all. I have 09 van. And I love driving in deep suburbs because of peaceful environment. Oshawa to Oakville and beyond. If u know how to work this area then u will never want to work in GTA. Especially for full-time people. For part timers it can be a hit or miss. I would like to know what other ppl think.
Santa
What time to what time do you work and which area you work the most?
Mine is a 2007 so I can't work in Toronto anymore. Haven't been on the road for the past two weeks because I was driving Toronto only. I haven't thought about or researched enough, which area I should be driving in.
Tdot
I live in Scarborough so I head east to Oshawa. It depends where u live. Oshawa, Ajax, Whitby, Pickering, Markham. People need rides everywhere, just like Toronto. U just have to hit the road.
Uberchampion
Toronto has consistency and constant pings. The burbs have longer rides but less pings.
Oshawa and whitby are good on weekend nights. Not so busy in the day.
If you hang out around uoit youll get minimum 10k rides between 8 and 11. Around 4/5 am youll get people going to work downtown before the go train starts up or airport runs. Its not that bad. Richmond Hill/Aurora have also been good to me.
