The Killshot
Nibiru
Its happening now..... no time to sit and uber; The time to make final preparations is NOW!.
http://www.thekillshot.com/
www.spaceweather.com
GEOMAGNETIC STORMS POSSIBLE TONIGHT: The first of two CMEs en route to Earth has arrived. First contact occured on Sept. 6th at approximately 23:45 UT. NOAA forecasters say that moderately-strong G2-class geomagnetic storms with isolated periods of even stronger G3-class storming are possible in the hours ahead as Earth moves through the CME's magnetized wake. High-latitude sky watchers should be alert for auroras in bright moonlight. Free: Aurora Alerts
MAJOR X-CLASS SOLAR FLARE (UPDATED): On Sept. 6th at 1202 UT, sunspot AR2673 unleashed a major X9.3-class solar flare--the strongest solar flare in more than a decade. X-rays and UV radiation from the blast ionized the top of Earth's atmosphere, causing a strong shortwave radio blackout over Europe, Africa and the Atlantic Ocean: blackout map.
tohunt4me
Often, accompanying seismic activities occur on earth in relation to geo magnetic stressors.
Space weather does affect earth weather.
Watch for earthquake and seismic tremors in 48 hour range proximity to this solar event.
Gamma wave radioactivity penetrate the very core of the earth itself.
There is no protective construct.
The entire earth is penetrated by this radiation.
The earths geo magnetic shield has become more vulnerable since the onset of polar shift on earth.
Some believe a strong enough flare could blow away the earths atmosphere rendering it similar to the surface of Mars.
We must sacrifice to the Sun Gods at once !
Amen Ra !
I invite You , fellow amateur scientist, to examine the co relation between Solar Flare and Earth bound seismic activity.
Explore the past.
Learn the Patterns.
You will see beyond what you are told to believe.
As in the Global Polar Shift they now pass off as " Global Warming".
The Globalists wish to snap up the arable land for themselves. To tighten their grip of control over mankind. What is good today, may be desert or frozen tommorrow. Once the equator relocates.
The Mayan callender coincided with the last narrow miss of earth by Coronal ejection.
Examine photos of the sun from that time in 2013. The Mayans worshipped the sun.
Their high priests were extremely advanced in star studies.
Especially our Star.
I will not tell you what to see.
Just where to look.
Certain Natural events produce anti matter such as C.E.R.N. is producing.
Lightening for instance naturally produce anti matter.
Research occurence of lightening over earthquake and volcanic sights precedent to activity.
Your body, the earth, all is electric.
The molten rotating core of the earth is a sort of generator which produces a geomagnetic shield a form of electricity.
Study the sciences individually.
Then see how they blend and cohese.
Nikola Tesla would have used the stratosphere itself as a free energy generator which coincidentally would have created a strong geomagnetic shield which would not have been weakened by Global Polar Shift.
His ideas were butchered because his financers would have no such talk of " "Free Energy".
Those who turn the Garden of Eden into a slum, and claim to own the rain.
FREE WILL
From Planetary Orbit
To electron and Neutron atomic rotation
The Universe is electric.
The patterns repeat.
" As Above, So Below".
tohunt4me
See what i referenced regarding solar flare and seismic activity ?
8.1 mexico. A few hours ago.
Its a regular occurrence
tohunt4me
N.A.S.A. is not the best source . if you want real time info that is not delayed seek other sources.
Maven
Thanks to the ionosphere, all the fuss and bother will be over soon. Without the ionosphere, we'd already be dead from radiation exposure.
