Rooted phones again
Fargle
Back in June, the Uber Driver app threw a fit over my phone being rooted. This was a phone rooted through the towelroot exploit, so if I undid it, there's no getting root again. I switched to T-mobile and have a rootable phone now. So, before doing the deed, I'm checking to see if rooted phones are still a problem. I started up the app on an older rooted tablet -- no problem. I could go online without the app balking.
Is anyone else driving with a rooted phone?
NGOwner
I am. Google Nexus 6 rooted. Running Xposed. I've never had a problem with either running Uber Driver.
[NG]Owner
RioRoja
Yesterday Uber forced me offline after I dropped off a rider and popped this message:
The TROUBLESHOOT DEVICE SETTINGS link redirects to
http://t.uber.com/device-issues
Coincidentally, I had updated the Uber app earlier in the day but was able to restore the previous, backed-up version via Titanium Backup. Even after clearing data and signing back in, I still received this notification, so it doesn't seem release dependant. I ended up reinstalling yesterday's update to the Uber Driver app and was able to go back online within just a few minutes and fake park in the airport holding lot.
Turns out the same thing happened to a buddy of mine just a couple of days ago. He, too, was able to go back online within about five minutes, so there seems to be some sort of timeout aspect. We both have rooted android phones. I'm on a custom 6.0 rom with Xposed running, however he's running a rooted-only 7.0 stock rom with no Xposed support.
Fargle
You said "fake park". If you're spoofing your GPS, that might have done it. I rooted my phone two days ago and everything has been fine except for unrelated problems that showed up before I did the rooting.
RioRoja
Yes I've been successfully fake parking for almost two years both in the airport holding lot and directly in front of the various large hotels in my city. It still works, however, the device settings warning along with getting forced offline for approximately 10 minutes can waste a DF session or make me ineligible for a rematch after I drop off at the airport.
UBER brought this 'feature' to London with app update 3.140.0. I just got text "Your device settings are preventing the Uber app from working properly. Visit http://t.uber.com/device-issues for more details" and actually I can't go online. I am using OnePlus One with SultanXDA: https://forum.xda-developers.com/on...m-kernel-unofficial-cyanogenmod-13-0-t3242700 and just tried RootCloack 2.1.1 module within Xposed 3.1 version 87 and it worked once but after going offline issue got back.
Any workaround till yet?
This sounds similar to my now not so useful recipe: rooted + custom TouchWiz deodexed rom + Xposed + Hide Mock Locations + FGPS installed as a system app (I don't think RoatCloack has ever really worked to hide root from Uber - at least on my phone).
Im running 3.144.1 on both a rooted (& custom 7.11 nougat rom) and a stock non-rooted 5.11 marshmellow release. One for uber, other for lyft, both apps loaded on each phone and i change up which phone is running what app.
Both phones have intermittenly given me the settings message last few days. I logout of uber, clear cache, and restart uber successfully. It sometimes takes multiple attempts, or waiting, not sure which to log back into uber & go online.
Interesting it also affects my non-rooted phone at the same time. Tells me its account related, the uber server apparently saves info saying this driver account is on a rooted phone.
My trusty sidekick and I have both come to this same conclusion. Once we figured out it's an account level flag, we both have a heightened level of concern over the possibility of getting deactivated for fake parking and are now both running Uber on non-rooted stock android devices.
Turns out that Uber is not specifically blocking root. It's blocking apps that it thinks you might use for location spoofing. Note my emphasis on "think" and "might", because this latest attempt has cast a net so wide that it's breaking other mostly unrelated apps. Uber has gone completely overboard and figured out a deeper way to detect location spoofing, but in doing so it has accidentally blocked what is arguably the most important Android app these days: privacy manager XPrivacy.
This XPrivacy app is vital to Android because it is the only way to effectively and automatically prevent the unfortunately common practice where apps slurping up your sensitive/private information (like contacts or your phone number). XPrivacy is also powerful enough to block many other parts of apps that need blocking. And it has a rudimentary and finicky location spoofer that DOESN'T EVEN WORK IN UBER, so Uber's blocking of XPrivacy is completely unnecessary.
To provide a metaphor for those that still don't get it: it's the equivalent of banning cars because they can be used to run people over. A gross overreaction.
So until Uber reverses this latest rash decision of theirs, sadly the only workaround is to just disable XPrivacy (meaning turning it off in Xposed, not uninstalling or disabling it for Uber). Also disable any similar apps and of course, anything that's actually related to location spoofing.
This deserves its own thread because it's not directly about rooting, by the way.
I toyed around with Xprivacy several months ago when Uber first launched the daily driver report. It was too complicated for even my nerdy self, plus I never successfully prevented Uber from gathering accelerometer et al data, so I removed it.
Mrjario
Hi everyone... im from brazil and sice february of 2017 i use fgps to "cheat" the app... im using xposed rootcloack and lucky patcher ( to clear data from driver app ), now im getting a serious message (in portuguese ) basically says; "uber has detected seetings that seems you are burling our service terms (...) if this ocour again your account will be permanently desactivated" ( my english is bad, i now ...)
So, anyone solved this ?
steveK2016
Stop violating the service terms should fix that up pretty quickly.
Rakos
You have big cahonies...
Coming on here and admitting to this...
How do you think other drivers feel...???
Rakos
BeaconDelta
I received tax docs from both rideshares this year that show miles driven while logged on, but not engaged in a trip. Obviously, this would mean Uber/Lyft are now paying close attention to geo-positioning and car speed outside of the ride. So, if pick-up times far outperform the system's estimate as a result of spoofing your location, no doubt they will know what you're doing now.
ASIDE: If I'm correct, maybe they won't care about the phones being rooted anymore. I play by the rules, however, the reason I need to root mine is to get rid of the factory installed adware popups and crapware that interferes with the ride experience.
