Lyft ratings
JG10
has anybody experience there lyft ratings gradually going down from 5 to 4.8 but there Uber's rating never being so high before?
Markeezee
Lyft counts the last 100 rated rides you've given so any 4-stars and below will drastically lower your ratings. Whereas in Uber, your last 500 rated rides are counted. It's easier to pull up your ratings with 100 rides, but the inverse is also true where if you've successively been given any ratings below 4-stars will lower it.
Uncle-not-Ant
Lot's of Uber Paxholes migrated to Lyft and rate like the crappy people they are. Lyft Line paxholes from south central rate low most every ride no matter what.
JG10
Okay that makes a lot of sense recently I been driving in south central a lot more often
automator
Look, just do everything the pax asks and you'll be fine.
Don't be like these entitled "knowledgeable" ladies, I mean drivers, that complain at the first hint of things not going their way.
Just accept everything and you'll be fine.
