Logan: porta potties are here!
Goodellsux
Nice row of 6 gender neutral commodes strategically located next to the "hut". Now, if we can just get the jerk drivers to stop ignoring the trash barrels, we'd take a big step towards gentrifying this lot:smiles:
Ghwwe72
I either use the bathroom at the Gulf station at the airport (has a Dunkin Donuts inside so usually get an iced tea or coffee) then I head to to the lit. Other times I use the limo pool. Not sure about the porta potties but we shall see!
Prime87
Never did an airport pickup but now with new filters I might. I don't even know where the damn lot is lol
Goodellsux
I generally pull into the limo pool to use the restroom, check the flight schedule, see what's posted on the bulletin board, and maybe buy something from the vending machines.
Understood and I like the fact you can get a Nathan's hotdog for a buck fifty from a machine that takes credit cards. I only wish I could wash my feet in the sink, though.
Good thing about the portapotties is that you can get in and stay in the queue while going for relief.
ubermaster5000
Do the filters work for airport? I figured the queue might mess things up if it is your turn to be called and there are no pax headed to your destination. Would that bump you the end of the queue again or will it hold you at the front of the line waiting for the right pax
Goodellsux
It won't bump you to the end. You are still next in line for each ping. Once the next ping matches your filter you are good to go.
One of the reasons the queue can appear inaccurate is that it includes X, Black and XL, along with filters.
B - uberlyftdriver
This is a good thing, now just some free driving lessons for some of these idiots and the queue might be a little more civilized
B - uberlyftdriver
follow the signs to the rental car center, keep going past it and the chaos will be on the right.
the entrance is around the other side, second light take a right
if you have lyft, push the arrow on the airport and it will switch to navigation
BostonTaxiDriver
Dandy, but drivers will piss or whatever, and then have no means to wash one's hands! Not that some of 'em do wash when sinks are available.
At least limo drivers would be considered classier, as some/most can and likely do wash their hands at real sinks.
Plus, don't you think sloppy drivers will miss due to poor aim snd piss all over the floor? So, you'll then drag your piss-stained shoes back to your recently detailed car's interior, along with unwashed hands.
Well, I guess we humans have and continue to survive under much worse conditions, so never mind?
