Help Destinations
Jackthecat
If I set my destination to anywhere at 30 minutes to leaving. Are they looking for a pax within the 30 minutes before leaving or after I start driving?
Sacto Burbs
They will send you a passenger to the maximum distance they can before you have to dead head home to arrive within the time frame you choose.
After that. If you are lucky you may get a ride on your way to your destination.
it keeps the far flung pings is away.
Jackthecat
Ok so if I know I'm leaving at 4 and set my destination at 3:30 for 4:00 it won't start looking until I leave at 4:00 .... right ?
Sacto Burbs
No
If you want to leave at 4, just turn on DF at 4pm
But...
Say You want to be home by 5pm. You ALSO enter that time
(Not the time you plan to leave, the time you want to arrive.)
It looks at traffic to see how long it would take you to get home from the next ride.
After the drop-off, it checks to see if you should be heading home.
if so, it tells you to go home and will try and get you a ride on the way.
