Full time driver - brake pads lasted only 10k miles?
Discussion in 'Vehicles' started by werty, Oct 10, 2017.
  1. werty
    werty Active Member
    The brake pads for a full time driver I know only lasted 10k miles. Almost all of it is city driving. Abnormal wear or expected?
    I don't know the specific pads but I assume he didn't use crappy pads. I can ask him if needed.
    tohunt4me likes this.
  2. Tysmith95
    Tysmith95 Well-Known Member
    Boston
    Abnormal wear. Even with city driving they should last longer then that.
  3. tohunt4me
    tohunt4me Well-Known Member
    new orleans , la.
    Abnormal !
    Im going on 70,000 miles on mine.
    The front ones( 4 wheel disc) are starting to get to the monitoring level.
  4. UberDezNutz
    UberDezNutz Well-Known Member
    Denver
    Driving:
    UberSELECT
    Really abnormal , I still was in spec at 70k miles of rideshare driving
    Or this person has no clue how to drive
  5. werty
    werty Active Member
    All of you are full time city drivers? 70k seems really high for heavy city driving.
    I've searched around and seen that 10k is normal for lots of sustained city driving, but I wanted real-world examples.
  6. tohunt4me
    new orleans , la.
    10 k is changing brakes every month driving uber
  7. UberDezNutz
    Denver
    Driving:
    UberSELECT
    Who's driving 10k a month on Uber??
    I typically drive just around 1,000 miles a week around 35-45 hours and net (after tolls, gas and uber/lyft fees) around $1200 . If I drove 10k miles a month I'd be bringing in over $10k a month net . Taking a quick look at my spreadsheet and only twice have I drove over 1500 miles in a week and both those weeks I made $2k
    werty and tohunt4me like this.
  8. Doowop
    Doowop Well-Known Member
    USA
    Look for uneven wear on pads: extensive wear on inside pad and minimum wear on outer pad. If so, probably caliper needs replacing.
    observer likes this.
  9. R James
    R James Active Member
    Bothell, WA
    Driving:
    UberX
    At 60K I figured I needed new brake pads and so I changed them, only to find they (the Honda originals) still had MORE THAN HALF left! Not sure how long the replacements will last but even cheapies being driven in the city should go way longer than 10K!
  10. observer
    observer Moderator Moderator
    long beach
    Your friend may want to have his brakes checked by a good mechanic. As DoowopDoowop mentioned, could be a caliper sticking. In my case, I had a bad master cylinder that caused me to brake with ONLY the front brakes.
  11. Spotscat
    Spotscat Well-Known Member
    Columbia, Missouri
    Driving:
    UberXL
    Front or rear pads?
    If the mechanic used some off-brand brake pads, or a counterfeit third-world knockoff, and they were on the front, I could see them lasting only 10,000 miles. It is by no means "normal", but under the right circumstances...
  12. observer
    long beach
    Unless you are at a dealer, 90% (more or less) of brake pads sold are off brand.
  13. PrestonT
    PrestonT Well-Known Member
    Las Vegas
    There is no worse driving for brake pads than on the Las Vegas Strip during night time. My original pads lasted 20K miles. I can't imagine circumstances where they only last 10K, unless one does rally racing when not Ubering.
  14. jspec
    jspec Member
    Moraga
    Driving:
    UberX
    sounds like the sub $20 autozone pads, mine didnt make it to 20k. Im also a late braker. Ive changed brakes and tires twice in 12 months. Never purchase chinese made tires (most of you probably already knew that).
  15. Another Uber Driver
    Another Uber Driver Moderator Moderator
    See avatar
    Driving:
    UberTAXI
    For most cars, I would suspect that ten thousand miles is too fast a wear out for the brake pads. The brake pads on some cars will wear faster than others. This can happen even in the same models of cars in different years. Sometimes it is poor design, sometimes it is the vehicle itself that simply is not well suited to this type of work.
    If it is not a mechanical problem such as sticking calipers, warped rotors, scored rotors or something like that, it may be that the pads are too small.
    I did not drive a cab full time for long, but when I did, the pads used to last about thirty thousand miles. This was on the larger Chryslers in the Capital of Your Nation. The cars had front disc and back drum brakes.
Share This Page
