? For seasoned drivers...
SheUbers
I realize the mileage along with the wear and tear on my vehicle is not worth the coins Uber pays - But I need to make some quick cash this weekend. Is it possible to pull in $150-200 on a Saturday evening/night?
Side note- I was a bit disappointed with the demand for the beer and bourbon event at the Amphitheater last night. I received a whopping two requests. Anyone with better luck?
Dahkei
It's not impossible but your a couple of weeks ahead of being able to do it with any kind of efficiency.
Which do you drive (X, XL, SELECT)?
SheUbers
Thanks for replying. I drive X and apparently Uber Select according to a recent text I received from Uber informing me of my newly acquired "select" status. I have yet to receive select requests though.
Dahkei
Cool. Select should help. Only problem is that if you can't opt out of X then your Select requests may be even fewer snice your time will be occupied with X.
Be sure to notice the bottom of the screen on each ping. This is where you will see "SELECT" if it's a Select request. You should also be mindful that when X is surging more people will order Select. Do the math to figure out at what point the X surge pays you better.
I don't drive X but my guess would be to get an early start on the night. Maybe 4-5ish, and expect to run through bar close to reach your goal. Your luck will still have much to do with the end result. God luck.
SheUbers
I appreciate your response
Stephen
I usually try about 8 hours on Saturday nights starting around 7-8 PM and only expect $100 on a regular basis. I lucked into a surge last night from Chapel Hill to Cary that put me over the top.
Undone
I had 3 requests to the beer fest from 20 miles or more distances. More than I expected, considering where I would end up (at Kokka Booth) and one from the fest when I was on Tryon Rd.
I only work during daylight hours and not a fan of picking up riders who don't know where they are amongst a thousand people. All in all, Saturday from 11:30 a.m. to 7:00 p.m. made about $160 plus some tippage.
Stephen
Uber will tell you to go to the places to make them the most money. It's typically not worth the hassle for two reasons. One, Uber has told everybody to be there. Two, it's a fustercluck trying to match rider and passenger in a huge crowd like that, especially at events at say, RBC which has a designated Uber queue/lot that the pax can't find and then they cancel on you, returning you to the rear of the queue.
Undone
My biggest complaint, among many, is the mileage rate. I mean c'mon. I'm actually considering a move with similar demographics and double the mileage rate. The other issues I can pretty much deal with, but I'm not out there to check out the scenery. $$$$$$
Disgusted Driver
The problem is that any time you do something based on your expectation of what Uber does is setting yourself up for failure.
