Do I need a vehicle inspection if I’m not driving?
DRider85
Is the Daly City Uber closed? Hate paying Jiffy Lube. We shouldn’t have to pay.
But also I’m not driving right now so does it matter if I upload now or later?
SHalester
If you are not driving, best to wait until you are weeks away from going online. Because, something not mentioned, once you submit an inspection the 1 year clock begins. Why waste the clock when you have no plans to drive right this second?
Taxi2Uber
Uber Greenlight hub charges for inspections now, here in Vegas.
Pay Jiffy Lube or pay Uber or pay some other place.
Lyft doesnt' charge (I think)
If you can get a copy of it and try using for Uber.
SpinalCabbage
You will be waitlisted until you renew your inspection. You'll be reactivated when you renew your inspection.
If you're a 20% driver there is a very small possibility that Uber will try and reactivate you at 25% if you let any of your paperwork expire. But it is a really small chance and you should be able to get them to put you back at 20% if they do try and screw you over.
SpinalCabbage
With Uber? Not allowed online, sure, but not deactivated. I didn't do mine for 3+ months after it expired, no issues. Did it recently and all was fine.
Yes. you're correct. Deactivated being not able to go online. Not permanently deactivated. Just deactivated until conditions are met... in this case renewing the inspection.
