Cheap dashcam?
UberZF
Livan, some que
I've used one similar to this for over 3 years... You can actually rotate the lenses in any direction.
http://m.ebay.com/itm/262487372332
First time I've seen that model. its interesting, that the title says 1080p, but specs say otherwise
Have a few questions ..
What are the recording options (For time in Minutes)
How big are the files?
Does it support High-Capacity (64G/128G/200G) cards formatted as FAT32?
How is the IR illumination for interior at night?
Livan
Livan, some que
Ok, mine is similar, not the same... You can choose 1,2 and 5 mins... For 720p files are about 50-60mb, VGA are smaller. 1080 never worked in mine (Same size as 720), but I was ok with it. I have a 32 GB card and the camera does the formatting (fat32 if I remember correctly). I don't use illumination cause I hate lights inside the car at night...and don't drive uber at night either. I normally use only one lens, but you can use both and point thdm in the direction you want. It automatically overwrites older files... I don't know/remember if it supports higher capacity cards...
