car Tire Inflator
RabbleRouser
I want to buy a portable car Tire Inflator
I don't know which is good
Please recommend it
THANKS。。。。
No issues going on 3 years.
I keep it onboard. Gives u independence 24/7 from Pay-for-air and Closed tire repair centers when u need ‘em.
⚠If u drive for a living it’s a must have.
Read the over 5000 owner reviews
EPAuto 12V DC Portable Air Compressor Pump, Digital Tire Inflator
amazinghl
The small probable air compress takes forever to pump up a tire.
I suggesting buying a full size spare instead.
Rockocubs
This one will blow it up before you can change a tire.
RabbleRouser
Full size spare weight will effect vehicle 🚗 MPG efficiency while decreasing luggage space. With ride share u need to squeeze every mile out of a gallon of fuel ⛽ for profit.
In my former Prius ride I removed the rear rubber backed cargo mat because of its unnecessary weight.
Then tossed out, cups, plates, knives, passengers.
Now I feel I’m at maximum MPG
Mainly because I sold the Prius last year after securing gainful employment
TheDevilisaParttimer
Unless you have an special need, I would just get a cheap $20 portable compressor.
Mine cost $25 from autozone. Takes less than 30 secs per tire max, then I’m on the road again.
amazinghl
You bought the wrong car.
This is with my 16lbs spare wheel/tire.
observer
1 to 2% increase in MPG per hundred pounds lost.
That will blow your tire once you put air in it again. That stuff is only good if your stranded on the side of the road and don’t care if you keep the tire.
mbd
Please recommend it
THANKS。。。。
I got one from Walmart, it was less than 20$... My pickup tire went flat, so used it... and it worked fine ( took about 5 minutes to inflate it, 265/)
