Big difference between 2008 and 2009 Prius?
Aharm
I was thinking about buying a used prius over 100k miles. Is there a big difference between the 2008 and 2009 models?
Mr_Frenchie
None.
Also, these 2nd gen Prius IMHO are better. Cheaper parts and easier to do DIY like oil changes. The 3rd Gen has open oil filter and not in a canisters. and real PITA to get to the spark plugs.
I can do a full Mobil 1 oil change with filter for $25.
Clifford Chong
There are no differences. Both Prius share the same chassis and design since 2004
The 2010 Prius is a different design with slightly better specs but more expensive.
Aharm
Thanks a lot for all your help Mr Frenchie. You are one of the better posters on these forums!
