08 and newer Nissan owners with CVT transmissions, read this
louvit
I just had a new trans installed by Nissan in my 08 Rouge. Nissan is aware that the CVT trans sucks so they extended the warranty to 10 years 120,000 miles. If yours is wining or anything get it there quick! Hope this helps someone.
tohunt4me
Nissan had such a good reputation.
Ford and Nissan has been plagued with transmission problems.
Standard shift transmissions are exempt.
UberDez
Ford transmissions are really only problems in their 4cyl cars their transmissions in bigger cars are very Stout
The worst is the focus and Fiesta dry dual clutch automatic not sure what they were thinking with that design
Every manufacturer has issues with their cvt transmissions, I get that they get better gas mileage but it's annoying that so many cars only have a CVT or nothing option. I will never own a CVT equipped car
louvit
Do you people know what the CVT is?. The trans does not shift, you will never feel a shift. CVT is Continuous Velocity Transmission. The car they gave me as a loaner while mine was being fixed was a 2017 Rouge and they are still using them. I guess they found the problem. What I do like is that it has paddle shifter on the steering wheel in case you have to downshift for more power to get on highway or something. Paddle shifting is awesome....lol
UberDez
Paddle Shifters on a CVT are about as pointless as it gets
also it's not Continuous VELOCITY transmission it's a Continuous VARIABLE Transmission
wk1102
CVTs have been around a long time and a lot of companies use them. Nissan had issues with them for a few years. I tjink 2010 and newer don't get the extension.
Here's a fun fact, 2009 and younger Nissan s with a digital odometer do not back up the mileage anywhere. It's stored on a chip on the actual odometer.
Keep up with radiator fluid changes and transmission fluid changes. (Drain and refill not a full flush and use niassiam cvt fluid) you only have a few months of warrantee left. Heat/friction is a killer to theses things.
I had mine replaced July last year.
louvit
thanks for the correction...lol and the paddle shifter comes in handy once in a while when merging onto a highway, I hit it twice and go from 6th gear to 4th....
kevink
GM messed with CVTs for a brief spell in the early 4 cylinder Saturn VUEs and ION coupes. The called it the VTi. They ended up extending the warranties on them much like Nissan has and for the same reasons (chronic premature failure). They never did get them right and didn't persevere with them thankfully.
